Old 21-05-08, 09:33 AM
lutman's Avatar
lutman lutman is offline
Originally Posted by Purple AK View Post
Just for reference. Here is Wilfs (now famous) Graph showing bore wear verses temperature! Pretty convincing evidence against Over Cooling, and using the car before the temp gets up!
Chris - I'd forgottem about this graph !
As they say a picture is worth a thousand words.
Also If the oil should overheat for any extended period - I was told over 200degC for over 5 mins then its best to change it. This was only achieved when I ran a 400cu.in tuned chev engine at air temps of around 30deg.C - I only saw temps over 200deg.C after around ten hard laps (Kyalami circuit) where revs were never below 3500 and usually over 5000.
And no I did not have an oil cooler installed.
Good info graph from Wilf /Chris
Chris Lutman - Daytona Coupe
