  #17 (permalink)
Old 21-05-08, 05:10 PM
Sidecarbod's Avatar
Sidecarbod Sidecarbod is online now
Originally Posted by nearly thers View Post
I haven't tried this but I think it should work, take off the hose for the clutch cylinder and connect the easibleed to this point rather than the reservoir cap. It will get a bit messy when you take it off at the end but you could always syringe some of the fluid out of the reservoir from the cap to avoid spillage. Just remember not to take all the fluid out so that you induce more air into the system.
Obviously you will have to bleed the clutch once it is all put back together but this is a lot simpler system than the brakes.
Neil
Er, Hello, didn't I post this suggestion? (Post number 8 )
Nobby and I just did his clutch again in about three minutes using this method.
Pete
