Originally Posted by Neil O Tony,
something I am thinking of doing is to change my crank pulley for a slightly smaller one.
I think the water pump could do with spinning a bit faster at idle, and also it would help the alternator keep up with the cooling fans at idle too.
I haven't found anything suitable in Real Steel's catalogue, do you know of a supplier and any pitfalls in changing?  |
Changing your crank pulley for a smaller one will slow down your water pump and alternator, not speed them up.
You either need a larger crank pulley, or smaller water pump and alternator pulleys.
Paul
