  #42 (permalink)
Old 22-05-08, 04:40 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Originally Posted by FatBoy View Post
Changing your crank pulley for a smaller one will slow down your water pump and alternator, not speed them up.
You either need a larger crank pulley, or smaller water pump and alternator pulleys.
Paul
It also will lessing the horsepower it takes to rotate the water pump an alt.
Normally with an FE the water pump pulley is a little larger.
To speed up the water pump they reduce the size of the water pump to a 1:1 ratio.
But with a smaller crank pulley and water pump pulley it also speeds everything up a little.
If you look at the pulleys in my picture the crank pulley and the water pump pulley are the same size but both are smaller than the stock pulleys.
Tony
"I couldn't repair your brakes, so I made your horn louder."
A Black Unique Motorcars 427S/C 427FE 482 stroker close ratio toploader 3.31 Jag IRS
