Originally Posted by Bob Harvey I have an AK with the Rover V8 and Edelbrock 500cfm carb. It has recently been to "Classic Cars of Kent" for the carb to be matched to the engine (High lift cams, etc)
What a waste of time and money...9 weeks later and they still can't book me back in. They only had a few needles, and hoped for the best...
Does any one know of a tuning company in surrey (around croydon?) that has a rolling road and can match & fit the correct needles or jets (I have the calibration kit) ???
Summer's here and I am fed up with "flat spots" and black unspent fuel exhaust.. |
Slightly unfair to post only one side of the story here Bob as Simon doesn't post here!. But he did tell me the saga yesterday!
From what he said you were booked in and he did an hours worth of setup and dyno runs. The car was running very lean, and you were told that this was due to the fact that the Facet Square Solid State pump fitted was not up to the job. (correct so far?) You were then told that rather than waste any more time and your money, you should go away and upgrade the pump, fit a Filterking regulator and obtain a calibration kit. Once this was done you could rebook and he would be able to sort it out for you. (again correct?) Sometime later you rang Simon on his mobile to rebook as you had done what he said, but he was in SPA at the time and asked you to ring back on the following Tuesday when he was back and he would book you in! Despite being told this you still rang him several more times over the weekend! You also rang Kent Classic Cars demanding your money back. Again you were told that you had paid for their time and they had told you what was wrong and what to do to rectify it. You became demanding as to when they should carry out the work and that they should give you written proof that the car would be spot on. At which point they said FU! Hence why you are still waiting after 9 weeks
Hope this clears up a few points
