Thread: Hello
Old 26-05-08, 08:15 PM
mclinc mclinc is offline
I'm off to North Weald in Essex on the 28th.
Car Limits
As for tyre pressure / geometry I'm sure something is slightly out because it seems to wanted to understeer a little more than I'd expect. A bit of tyre sequel from the front (I think) on right had T junctions at pedestrian speeds too.
But I've only had chance to drive it once on the day I picked it up and I have to admit I've not even checked the pressures since I got it.
Andy at GD did say that it was going to need the suspensions setting up after it had loosened up. It's only done a couple of thousand miles from new.
I'm not sure what a good starting point for the pressures would be. I guess about 22psi on all corners after doing some searching.
Mike
GD427 CHEVY LS6
