Originally Posted by RichDyne LMAO - They seemed ok before the we took the engine out so don't expect anything to have happened. To be honest it sounds more internal than air moving.
Something went through my head before (rare but it does happen now and again). Could it be possible that such a noise would come about from a hydraulic tapet not being filled correctly with oil? If it is how could I check this - I assume its possible to move a push rod with the rocker off......
Might whip a rocker cover off in the morning and check if there is something obviously wrong going on.
Cheers Pete.
Rich |
The lifters will fill with oil after several seconds running so I don't think it can be that. Still worth poking around under the rocker covers though.
You could remove the plugs and the covers then turn the engine over by hand to check that everything is opening and closing as and when it should be. (not sure how much this will help but it won't do any harm)
What sort of breather system are you running?
Pete
