| If you have some sort of lip at the top of the bore, then at least it needs measuring and a rebore, same for your crank too.
__________________ David SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign. http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself" |
