  #13 (permalink)
Old 06-06-08, 09:03 AM
ian_uk1975 ian_uk1975 is offline
Originally Posted by Nobby View Post
Ian, do you have access to an engine hoist? I had to use mine when removing the intake manifold as it was stuck fast. I removed the carb, bolted on a lift plate and applied some lifting force with the crane (not a huge amount) then went round the seal with a stanley knife. It eventually just popped off. Easy.
It's also the only way I can remove the roll hoops. They really jam in place so I used nylon straps from the crane to pull them out. Better than a hernia!!
Good luck
Hi Nick,
Nope, no engine hoist
These are the sorts of things you just don't think to factor-in when doing something that should be a '5 minute job'. I wouldn't have expected to need an engine hoist to remove an intake! Oh well.
I'm going to try again tonight with a large screwdriver from the front of the intake.
Thanks,
Ian.
2003 DAX Tojeiro De Dion
