  #15 (permalink)
Old 06-06-08, 11:54 AM
ian_uk1975 ian_uk1975 is offline
Originally Posted by JonnyT View Post
I have to say I winced when I heard about the levering on the thermostat housing!!
You can get long scalpel blades that are also very thin - might get a bit more of the jointing stuff cut between the mating faces - its amazing how many problems you can get from very small amounts of that stuff.
I've got an old, wide, blunted chisel that I use for breaking joints like that - it doesn't do as much damage to the mating faces as a screwdriver.
Rubber hammer might also help to break any carbonated stuff that is all adding to the sticking power.
I know, I know, but it was the only thing I could lever with!
I've got a chisel, but it's pretty new and very sharp. Might be worth gingerly trying to tap it between the intake and block though.
Will try rubber mallet, too.
2003 DAX Tojeiro De Dion
