| I have a MK2 and had front tyre wear problems. I took it for an MOT and the tester thought it was the camber, i took it for an alignment check and all was within Pilgrims spec, it turned out to be a combination of tracking and bad tyres.
The guys on here suggested a top adjustable wishbone, as I believe it is under less load than the lower. I was thinking of trying a MK3 upper wishbone as it's adjustable, and got some dimensions from Gareth(i think). The dimensions should be in an old post. I no longer has access to workshop but i believe a set of wishbones could be made.
HTH Stu. |
