Old 08-06-08, 09:58 AM
stevee8's Avatar
stevee8 stevee8 is offline
CRC Wessex Area Rep
David,
What size motor and state of tune? This will affect comments/suggestions.
In the warmer weather you will get quite a lot of heat soak in the engine bay.
Your 81 deg engine stat should be OK but what range is your fan stat?
If it's a high range you may find fitting a lower one will improve things.
Once the fan kicks in, does the water temp stabilise or continue to climb?
If the latter, then you may need to look at increasing the fan output - perhaps someone can confirm if they are running a single 16" successfully with a similar setup?
For definitive values, the gauge readings won't necessarily be particularly accurate.
Steve
