Old 08-06-08, 09:58 PM
craggle craggle is online now
Veteran polisher.
Good to hear it's running.
Most powder coats are sprayed on plastics that are then baked on in a big oven. The oven will be cooler than the header temperature so I would imagine any powder coating is simply going to melt and probably burn?
If the pipes are stainless leave them unpainted, If mild steel then not a lot you can do except watch them rust.
Ceramic coating is a possibility but I think this has to be done on fresh steel or you will need to get them blasted to clean them.
Polishes to date = 17
