Advice on fitting gearbox Ford 302/351 I'm after a bit of advice...
Anyone got a Ford 302/351 fitted in a Sumo??
I have a Seirra T5 gearbox I could use - but is it strong enough?? Not planning on going above 300hp, as I've been told this is the chassis limit by Pilgrim.
Anyone know if the Sierra box will fit? Or whether I'd need a different length input shaft? Or any other issues I might run into?? With sourcing flywheel, clutch etc.
Will the mustang bell housing be any good to fit marry the two?
I would like to understand fully whats involved??
I've a MK2 sumo, so this engine is not a Pilgrim supported fit, like it probably is on the MK3??
Many Thanks,
David |
