Originally Posted by Gazzab Getting to the stage of fitting all the shiny bits etc and was thinking off fitting the rear fog lamp the min height is 250mm i think but is that to the center, bottom or top??? was hoping to fit under the rear end to avoid drilling the rear panel.
Gary |
Its to the bottom of the lamp, ie the lowest light emmitting part of the lens has got to be a minimum of 250mm from the floor.
Of course you can help to achieve this through raising the rear ride height if necessary.
Tony
