Originally Posted by aksportscars Mark, your rad cap has to seal at the bottom. If it only seals around the top then your water will not be under pressure and it will continue to chuck it out of the overflow.
Regards Lynda
P.S. Thank you for the card |
Hi Linda,
From what Mark has described, he has a rad with a pipe from the overflow to an expansion tank; I assumed from hois description he has a blanking cap on the rad with a pressure cap on the expansion tank and the rad overflow pipe going to the expansion tank. This should work, but maybe Ive misunderstood what he has?
