Old 18-06-08, 01:14 PM
JonnyT JonnyT is offline
Does it do this repeatedly?
Had problems to start with as a result of air in the system (Jag brakes are a pain to bleed in this set up). Pedal was soft until I bled the system many times. Never went to the floor though - if it does it repeatedly then it may be another problem.
One issue that we did have is that the one way valve on the vac hose to the servo has instructions and markings which are pretty confusing (Simon and I read it before and after finding the problem and it is by no means clear). Try turning the one way valve round and seeing if that makes a difference. Before we did it the brakes were not good.
Bedding in has made a huge difference though to our brakes.
