Originally Posted by yellow peril cheers guys...now the million dollar question..could a numb nut like me fit one???
martin...aka numb nut |
I found it pretty straightforward. I got bits from Real Steel, they suggested I use black RTV on the inlet manifold gasket around the water ways even though I used a composite gasket, the new throttle cable was a bit awkward pedal end, but the hardest part was bleeding the air out of the coolant, I ended up drilling small holes in the thermostat and filling the system through the top hose into the engine not into the expansion tank.
HTH Stu.
