Hi and Welcome!
I had my sidepipes made too...so I can't say what the Pilgrim method if fitting is.
But, I have steel L shaped bracket welded to the chassis under the door area. With a (mini type) rubber bobbin bolted on top, then the sidepipe (with a bracket welded underneath) sits on top of that. There is also a smaller bracket attached to a body mounting bolt, another bobbin and bolted to the sidepipe under the bend as it extis the body for extra support....
Works for me!
I think like most job's, it's a 'make it up as you go' thing...
Having said that, I'm sure lots of people know their own 'tried and tested' methods.
Good luck!
__________________ "...55mph!!....slow enough to make you think your safe.....but fast enough to kill you!..." : Gumball Rally 1976.
Jan & Chris.
MK II Sumo RV8 |
