Originally Posted by Robin427 I need to use some washers - the bolts are too long otherwise (same length and strength as the Image ones I removed). I suppose I could double up normal washers - same weight. At least now I know that this wheel has been problematic, I'm likely to keep a closer eye on it |
Robin if this wheel is a problem and only this wheel, then bloody replace it. If you are breaking bolts you could be putting your life on the line. Would you fly one of your planes knowing that one of the wheels could fail? I think not!
Stop PI$$ING around and sort it once and for all otherwise your signature could be put under scrutiny.
