Old 23-06-08, 10:21 PM
Stu J's Avatar
Stu J Stu J is offline
club supporter gold
From the front of my chassis the first wishbone bracket on the (good) o/s is 100mm, compared to 115mm on the n/s.
The suspension upright on the o/s is 40mm away from the rear wishbone bracket, compared to 45mm away on the n/s.
The cross member between the front chassis which has the steering rack mounted its different either side so that geometry can't be right.
Assuming however the chassis IS supposed to be like that why would you need to achieve different calculations in order to get the steering and suspension set when the welds are clearly different?
C an
O nly
B e
R eal
A drenalin
