Originally Posted by yellow peril I need to do an oil change on the gearbox.Its a rover LT 77.How much oil should i put in it and what is the best type/make to use.
many thanks Martin |
Martin,
I would use 75/90 full synthetic oil the type I use in mine is Mobil I , I would'nt use ATF it was only used to help cold gear selection, and exagerates wear on the bearings, the filler plug is near the tail of the gearbox and is also a level plug so just fill it until it runs out.
HTH
Alfie B
