Old 26-06-08, 07:30 PM
philip600's Avatar
philip600 philip600 is offline
Hi Andy,
As I said it will depend on diameter of your tube but mine are 275mm centres & 225mm between the tubes which are 50mm diameter. ( 275 - 50 = 225mm ) As you've said you will have to fabricate the inside mountings so I would get the hoops made first & position mounts to suit !
Regards Phil.
Four2Seven
