| That dosen't sound right.
If it's a limited slip diff and you turn one wheel the other wheel will also turn at the same speed with it, As if they are on the same shaft.
If you turn both wheels one turn then the prop should do either 2.88, 3.01, 3.31 or 3.54 turns
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money!
Polishes to date = 17 |
