Old 07-10-08, 08:53 PM
What_was_I_thinking's Avatar
What_was_I_thinking What_was_I_thinking is offline
Smile
Thanks for the info Jeremy..
Do you happen to know if V8 Chevy and Ford rockers are similar apart from rocker ratio? Thinking Chevy ones maybe the ones to try.
Interesting what you say about the rocker posts... I was going to roll pin mine in, but was adviced that it wasn't required by a local engine builder.
Think I may reconsider after what you say.
I haven't quite got your spec yet but close, apart from milder 290 kent cam and a 40DFI5 carb at the moment, but was planning 48IDF convertion later on, so probably best to sort out the rocker posts now.
Many Thanks,
David
