| Rover v8 dumping coolant if all the above fails contact me as my uncle had the similar problem with his Rover V8 and it was a bit more sinister! Aluminium block?? possibly the ali was breaking down and the air was being created by the pistons going up and down, very rare but you can get cross bore leaking. I'll mail hime for more info if you need it - but not wanting to panick you , like I said contact me if all the above fails. for the record his V8 was in his range rover. Took him 3 months to sort in the end under warranty the garage replaced his block. |
