RE: Making the right selection
Are the dowls still in the block, to line up the bellhousing. If not you will have to dial it back in, but that means an engine out. x(
Were the load crunching sounds like when you try and change gear without a clutch or just a general crunch as the gear is engaged?
Robert
Forum Admin
Best Regards
Robert
