RE: Making the right selection
Some responses:
Oil - I'm now using ATF fluid. Initially I had put some gear oil in but it was suggested here before that I change this, so I did.
Bellhousing. As Rob suggests there are dowels on the bell housing that help align the box to the engine, so that eliminates that problem.
I've not really tried with a warm box (oo-er) as I normally just want to drive the thing in/out the garage, so things are probably cold. What should happen when it's warmed up, easier selection? Better lubrication of gear, etc?
Thanks,
Tony B
