Old 12-02-02, 12:08 PM
mikey mikey is offline
Caster & Camber Setting.
I would be grateful of your advice/experience in geometry set up. I have had the caster camber set up twice on mine but I am experiencing a lack of bite from the front end on cornering which leads to a lack of confidence. Also noticed greater wear on the inside of the front tyres. Ignoring the inevitable comments about Dax’s not going around corners I feel that it is nowhere near what it should be on cornering ability. The people who I have taken it to in the past ( 2 separate garages ) certainly knew how to charge and one used an optiflex system, the other laser gauges. However they did not inspire confidence in me that they knew what they were doing although they talked a good story. I am not talking high cornering speeds, at moderate speeds there is a feeling of drifting on the front end. Everything is tight and no wear etc. Can anybody help advise me as its an area I can not get my head fully around as to whether caster or camber or both is likely to be causing the effect. A web site thjat goes through troubleshooting would be useful if anybody knows one. I am not adverse to paying for setting up, but as I say, twice so far.
I would appreciate your thoughts as I am running out of pairs of trousers.
Regards.
Mike.
