Old 07-11-02, 09:24 PM
Dax SC's Avatar
Dax SC Dax SC is offline
front overriders-grille bar
Hi
I'm in the process of building a Dax Cobra, and I am fitting quick lift jack pads instead of the usual grille bar and overriders. As you can see fron the attached picture, I have fitted the rear jack pads, the position of which was determined by indents moulded onto the body.
My question is, can some one tell me the exact distance between the front supports (measured from centre to centre) that pass through the body work, when fitting the grille. I need to known this as I may wish to retro fit a grille at at later stage.
Thanks.
Mark Smith
