Old 16-08-02, 02:19 PM
Steve Senior Steve Senior is offline
RE: Rover v8 EFi or Carb ?
Marcus
When I got my engine it came complete with Fuel Injection system. It is dead easy to wire as all the temperature sensors and injectors have slightly different plugs. All you need to do is feed 4 or 5 wires from your main loom (feed, ign feed, coil -ve, and power to fuel pump from memory). My unit had been sat in a box for 2 years and worked first time without fault. The ignition system caused me far more problems.
My only recommendation would be go for a hot wire system rather than the flapper valve as the hot wire is said to be more reliable and can be chipped (so I am told).
Steve
