Old 03-04-02, 07:35 PM
wilf wilf is offline
RE: Ford Windsor 353 data/replica Hallibrand wheel knock off
Nicko - 351W timing "static" 16degrees btdc, should have about 18 degrees of mechanical advance, all in by 3000rpm, total 34degrees btdc at those revs. You can set the "static" timing up to about 900rpm, disconnect any vac advance you may have. Possibly worth checking that your crank pulley markings and pointer are acutally correct at tdc first, it is not unknown for this to be out.
Dwell or points gap- depends on what distributor you have. Let me know.
Knock off spinner - try Image wheels, 0121 522 2442. Check the OD of the "shank" of the spinner you want to be sure (measure ID of the wheel centre hole).
Is there any particular reason you refer to your engine as a "353"??
HTH
Wilf
My opinion is worth exactly what you paid for it. By the way - I was Right!
