| RE: Body Fitting ( GD Jag) Malc,
As Tinka says, don't worry about the ride height at this stage, things need to settle and you will need it fairly high to get light heights correct for SVA. If your looking for ISH ride heights then look for about 1" gap tyre to wing at the front and 1.5" to 2" at the back. My body sits on the foam strip at the front.
Jim |
