| RE: Break pipe layout hi allan
A bit late today to get you some photos but i will thry to post some over the weekend,
I have run the rear brake pipe round to the nearside and about 2' from the bulk head mounted the compensator valve on the top of the frame/rail. dont forget to mount it at a 27% angle !
I then ran the break pipe from the compensator to the bulk head, then across the transmission tunnel and ran the pipe down the tunnel for about 12" and then added the T piece. The rear brake pipe for the nearside then contunued down the tunnel and the rear pipe for the off side is run up the nearside tunnel, accross the tunnel, then down to the off side and then continues to the rear.
Dave |
