Thread: Sumo alernator
Old 19-05-03, 07:08 PM
Dan Dan is offline
RE: Sumo alernator
Wasn't able to take some photo's of the actual fixing point for the tensioner bar. It is fixed to a threaded spindle that has a couple of nuts that are used to set the distance from the engine that the bar is held. It isn't an ideal setup as there is a fair amount of flex in it which results in the alternator shaking slightly - it still however outputs a steady 14.3V back to the battery.
It may be worth considering beefing up the way in which the tensioner bar is attached to the engine so as that multiple fixing points are used - This is a modification I am already planning. Has anyone else with a rover engine changed from the Pilgrim method?
