Thread: Wiper Setup
Old 11-06-03, 11:50 AM
David Horsnell David Horsnell is offline
RE: Wiper Setup
You should not use the chrome angled shroud for the wheel boxes, Pilgrim suggest using 13mm heater hose cut to length and put over threaded part of wheel boxes and then pass through body and put nut on end. Bodywork is already angled so the chrome part is not needed.
Use a washer between the nut and the body or you'll knacker your paint / gel coat. Pilgrim use thin fibre washers as steel ones with the correct inside diameter have too big an outside diameter and look a mess.
If you've got their new build manual, its described in there.
David
