Old 13-06-03, 02:06 PM
David Horsnell David Horsnell is offline
Fuel filler flange
Help please. I'm fitting the fuel flange and find that if I use a jubilee clip to hold the filler pipe to the flange, I cant then get the nuts on the bolt that hold the flange to the body. I'm using a Europa PO18 locking flange but it appears to be the same bolt pattern as the Pilgrim supplied flange.
Do I need the top jubille clip as the hose seems to be a tight fit around the flange ?
All advise gratefully received.
Also, I'm using ETB instruments from Pilgrim. Has anyone got a photo of their home fabricated mount for the speedo sender that goes next to the daisy wheel ? and how many fins in the daisy wheel should be left up and how many bent over.
David:tu
