| RE: Fuel filler flange Photo's would be much appreciated.
I have tried that postion but cannot get the entire head of the transducer "in line" with the daisy wheel. Does it still work if the centre of the tranducer is pointing at the outside edge of the daisy wheel ? ie some of the transducer (half of the threaded bit) is outside the circle of the daisy wheel?
David
Tony, is your Sumo in gel coat, if so how did you finish the ground edges of bonnet / bootlid etc ? |
