| RE: Expansion Tank you don't actually need an expansion tank if you are using a dax rad
you can use a quinflex tr37 flexible top hose and an inline 1 1/2"
water filler neck available from real steel part no.by63730 . it costs
around £23.00 . it may not look quite as pucker but your wont cook your engine, i've built over 30 daxes this way with no problems . good luck.
__________________ Pro Dax Builder Current builds:- Dax No.126---------Kirkham No. 1 DB REPLICAS  Low Volume manufacturer |
