Old 25-06-03, 07:26 PM
Kevin W Kevin W is offline
RE: seat belt strengthening hoop
Hi,
I just drilled 4 holes for twin roll over bars - and had to go through the metal strap you refer to. Its bloody hard work but can be done. I bought the appropriate hole saw (2" I think), used coarse cutting compound and a very slow drill speed. Getting through the fibreglass was easy. After Id removed the fibreglass 'disc' then cutting through the metal just took time and patience and a steady hand, and (remarkebaly) not too much pressure. (I was using a 12V portable drill and the clutch on it kept squarking if I went too fast).
By the way, my method for roll bar hole cutting was as follows-
take a piece of rigid plastic pipe (as used to connect washing machine outlets etc, costs about 50p /metre) and make a masking tape skin over one end of it, so it looks like a 'drum skin'.
Then wrap layers of tape round the outside of the other end till it just fits/squeezes into the roll bar mounting bracket, with only a small amount of clearence between the top 'drum skin' and the underside of the body tub.
stuff the padded end into the roll bar bracket, and use a mini spirit level to check its vertical alignment.
after much measuring drill a 1mm pilot hole through the bodytub where you think the centre of the roll bar tube should be.
Top skin on the plastic tube should be pierced by the drill bit. Remove plastic tube and inspect hole - If its in the centre, then apply hole saw. If not, try again with another 1mm hole, taking into account the amount of error on the initial pilot hole.
By the way, the rear wings are rather assymentric (at least on my body tub).
cheers,
Kevin W
