Old 05-07-03, 12:21 PM
dave jenkins dave jenkins is offline
RE: Fuel gauge sender fitting
I drilled the tank useing rags and a magnet to catch the swarf.
If you insert the bolts "sticking up" these can be secured with a turn of wire on each one. loose fit the gasket, sender, washers and nuts, remove the wire and tighten.
Dave.
