| RE: Very Little Oil Pressure ! TINKA
I have another second-hand oil pump on the way to verify if this is the problem. There is definitely bad scoring in the bottom part of the relief valve bore.
If this proves to be the problem I would like to invest in a new pump , modified as you suggested, did RPI do the honing work as well as supplying the pump ?
Steve
:tu |
