| RE: carbs vs EFI Tony, is that a flapper system or Hot wire. The hot wire is well worth having as you can tune it quite a bit,and inprove the power out put. The flapper system can be tuned, but for any significant power gains it will start to cost you, as you will have to replace the flapper system and get an after market controller.
By the way how is the build going ? will try and pop over sometime but things are really busy at the moment.
Martin :tu :tu :tu :tu
