| Flywheel & bellhousing query Can anyone shed light on fitting the flywheel. I have a repower billet variety to fit to a 1989 chevy SB. I will be fitting a TKO500 eventually via apepower bellhousing.
NOVICE alert.
The flywheel when offered up does not easily fit on the boss and appears to require persuassion which I am not inclined to give at this time, .I was lead to believe that the flywheel fit is a snug fit not an interferance fit.
When I get to clocking the bellhousing in is it done with the flywheel fitted?
And after reading all the posts on the subject has anybody put together a photo record of the process including the assy of the clutch throw arm and bearings?
confussed but happy
david
__________________ GD427Mk3 Chevy 350CI On the road May 2008 |
