| Re: Flywheel & bellhousing query Hi Again,
I forgot to mention use a clutch alignment tool when fitting the friction plate, otherwise all your effort aligning the bellhousing will be wasted as you won't be able to get the gearbox input shaft in properly.
Most decent clutch kits come with one.
Good luck.
Chris |
