Old 13-10-04, 03:07 PM
russell_ram's Avatar
russell_ram russell_ram is offline
Club Treasurer
Re: Jag Speedo Sensor
'I must admit that I'm not familiar with a speedo sensor going in the diff'
FYI : XJS, cast Al cover, below the breather. 10 pulses per wheel rev, picked up from either a machined 'castlation' on the RH half of the PL unit or from the later, cost reduced, pressed on steel version of the same.
Pick-up is the same as the one used on XJ40 - but on XJ40 it mounts to a cast Al bracket which positions it to pick up off a pressed ring mounted on the (LH?) output shaft.
Russ
