Old 06-11-04, 10:11 PM
TonyD TonyD is offline
Re: Prop shaft length
I'd make the propshaft guy two drawings, one from above and the other from the side showing all measurements and, if possible, angles. This will give the manufacturer a good idea of the angles the prop has to drive through. A simple length measurement may not be enough unless the diff flange and the gearbox flange are in direct horizontal alignement.
Mind you I started off with a "skipping rope" for a propshaft so what do I know !!
Tony
