Thread: Help
Old 11-11-04, 04:09 PM
Grease Monkey Grease Monkey is offline
Re: Help
You could do it two ways:
1) Copy everything you want to keep to your second hard drive (100gb) and plug it into the new PC.
You may need to move the jumpers on the drive, depending on whether it was setup as a slave on IDE1 or or master on IDE2, or whether its set as a 'cable select' type.
2) buy a 4 port mini hub, plug the two together and suck the data accross the network. You could them keep the old pc as a file server and online backup facility.
