| header/expansion tank position for LS engines Hi all,
I tried test fitting my header tank last night & it looks like the mounting holes need to be drilled *under* the cross member rather than on the top. (lowering the overall height of the tank)
The reason for this is
(a) bonnet wont close (although body is sitting slightly low, as its not bolted up yet)
(b) water outlet from block is not lined up with tank otherwise
(c) Any higher and it looks like it would foul the air intake tube (which I dont have at the moment)
Any thoughts/ confirmation??
Cheers...
__________________ Welcome back my friends to the build that never ends.... |
