| Re: header/expansion tank position for LS engines The water tank is very close to the air inlet on the LS (hence the shorther water tank), but as long as you mount the water pipe from the block to the tank in a straight line, then mark the holes for the mounting bolts on the crossmember, it cant really go anywhere else.
__________________ Steve - AC 04 COB
GD Euro, 427 C.I. LS7, 540 hp... |
